Air Flow Dynamics
Gentlemen, I would like to throw one more idea out to be gnawed upon. Forgive me, I dont want to step on anyones toes. That being said, Here Goes! Has anyone considered how the air flows through the piping system that we are modifying? I see no air flow engineers among us, Just common sense applicators. One thing that we are not seeing is turbulence. No matter how pretty our stainless pipe or the blue hoses and clamps, the air flow efficiency is only marginally increased (my opinion, Stir up debate and causing us to put on our thinking caps). Each 90 degree bend is equivilent to many feet of pipe with the same internal finish. In the natural gas industry, That equivilent was 10 feet for every elbow! ( this is important because at high pressure, high flow rates, an accurate measurement of this commodity is impossible without smoothing out the turbulence accumulated through the distribution piping!) The worst offender in our equation is the intercooler. No matter which one you use there are 2 abrupt 90 degree turns, one inlet,one outlet! Let me do a SWAG and suggest that we are pushing air through the restriction equivilent of, say 60+ feet of pipe because of the turbulence accumulated. Some examples of turbulence elimination; (1. ) Those of you that are familliar with GTAW ( TIG welding ) have probably seen and used a GAS LENSE COLLET BODY. This has a multiple layer screen ahead of the argon distribution ports that straightens out the flow of the cover gas allowing for less aspiration of atmosphere around the edge of the gas column. (2. ) Tube bundle diffusers used ahead of of a TURBINE GAS METER to eliminate turbulence so a proper measurement of use can be made for billing purposes. (3. ) Sheet metal guides inside large industrial ductwork at abrupt 90 degree turns for distribution of building air/ AC. There are suppliers of diffusers for our application, but we can also build our own. A diffuser between the air filter and the inlet of the turbo has already been established in another thread. I would propose a diffuser as close to the intake manifold as possible. I know you have your boost gauges. But pressure is not volume! You can get more volume at the same pressure by eliminating turbulence. What do you all think? =). GregH
