Late afternoon brain child idea of mine to remove a rusted on dually wheel.
Yes, we could have put the outer wheel back on, just "snugged" the lugs back up, jacked the truck up off the jack stands, set the truck down and drove around the block. But I figured if a puller can remove a crank pulley, and a hydraulic press can remove a bearing, then a bottle jack and a length of chain could remove a wheel. It worked, and we only had to release and re-seat the jack four times (worked around the rim). In hindsight, a second equal length of chain to attach to the other two holes in the rim at the same time would have made it easier.
EDIT - Note, that is not me in the picture, it is a local TDR member that I was helping do a LP relocation and install some air springs on his 99 3500.
