2nd Gen Non-Engine/Transmission Need '99 Front end parts
2nd Gen Non-Engine/Transmission SUVlights.com
Lordsman
Hello,
I have a 1999 Ram Cummins 2500 4x4 with a Dana 60F front axle. Have to replace ball joints, tie rod ends, wheel bearings, etc... she's got 195k miles on original parts, even the track bar! yea, it's time, lol...
Found Moog greasable upper and lower ball joints and they are on order
Part#K80026 upper, Part#K8607T lower; as I've heard these are the way to go. Everything for $260 bucks (2 upper and 2 lower).
I need to replace track bar, tie rod ends, and whatever else is under there because it's time. Have a good mechanic to install all the parts I get rounded up. Thats where you guys come in! I need help knowing all the specific parts I need to replace and the best places to get 'em.
From dealer I was quoted on Tie rod ends #52038665($72/ea. ), Track bar assembly #52039440($240), and value line rotors #V5018314AA(#68/ea. )
Probably should do wheel bearings, brake pads, and whatever else you give me a heads up on. Ive heard about the Lukes Link for the track bar just don't know if I can use the existing bar and use their link end, maybe someone can clarify?
I just put in Bilstien Shocks(Geno's) all the way around btw, nice!
Thanks in advance, Mike
I used the lukes link on the track bar then went to 3rd gen style bar from spohn performance, a lot more affordable than other brands. Using lukes links on all the other tie rods though, very pleased with them. using powerslot rotors ordered from autoanythingn best deal I could find
