Hello. I have a 1997 Dodge Ram 2500 Cummins diesel 4x4 long box. I had the rectifier block replaced in my alternator at the repair shop last fall. The other day I suspected that the alternator had failed again as there was no charging voltage. I brought the alternator back to the repair shop however it tested OK. I'm wondering if the voltage regulator has failed in the PCM? I don't show any voltage (0 volts) at the two small terminals on the alternator housing. The main lug shows battery voltage. The truck starts and runs OK, just shows battery voltage. I've cleaned all the alternator connections, I've looked at the wiring harnesses for broken wires...everything looks ok. I removed all 3 plugs from the PCM, opened them up and cleaned all the connections and contacts with contact cleaner, plugged them back in. I still don't get a charging voltage. My research shows that the voltage regulator is in the PCM. Is this a common problem? Does it actually fail sometimes or is this unlikely? I'm currently at a loss... I'd appreciate anyone's thoughts to help me out. I've read that some people actually install an external voltage regulator. Are there any precautions doing this? Any helpful suggestions/links would be much appreciated. Thank you. Brian.
