I finally got around to changing the factory fill brake fluid. The old stuff kind of had a stale smell and I noticed some small "stringy" like stuff floating in the old fluid. Fluid was pretty dark color. When I sucked most out of the master cylinder I have a dark film layer of gunk (sediment ) in the bottom. I do not know how to get this stuff out without stirring it all up and then having it get into the rest of the brake system. I also did not completely remove all the fluid from the master cylinder because I did not want to get air in the system. I did as stated in the article for brake bleeding in issue 30 and left 1/8" fluid in bottom of the reservoirs. What should I do leave it alone or remove all fluid from reservoirs to clean and deal with possibility of getting air in the system. I have 4 wheel ABS and after reading my DC service manual it sounds like a major PIA to bleed air from the 4 wheel ABS system.
The article in issue 30 says to use alcohol to clean the master cylinder out, does it matter which type... . Isopropal (rubbing alcohol) or denautered alcohol.
Finally, I used a mighty vac pump connected to the bleed screws. THe directions said to remove and place teflon tape on the threads to get a good seal for the vaccum to work good. I did this, my question is do I need to remove the teflon tape from the bleed screws now that I'm done?? I don't know if the brake fluid will react with the teflon in the tape and contaminate the system or cause problems. please help
