I decided today to swap out the cheap brake controler my upfitter gave me and replace it with a Prodigy controler.
When I installed it and connected it to my trailer the controler blinks:
. C. then S. H.
Apparently there is a short or bad ground. I want to pull out the 7-pin connector on the truck and check all the wires and make sure they are connected correctly and securly to the connector, but I want to make sure I know Dodge's 2008 4500 wire color coding schema. That is, the wires from the truck.
I can't seem to find anything out there on the web that has the codes and the original Upfitter's instructions were discarded by the Upfitter after they installed the dump body.
Thanks in advance.
. C. then S. H.
Thanks in advance.
