Gonna pull the trans for the 4th time. I noticed a few other 5spd topics on here lately, so hoping someone knowledgeable on the Getrag can advise me.
Couple years ago, a front countershaft bearing blew up on me at highway speed.
#1. I pulled trans, took to local trans shop for rebuild with new bearings, seals, syncros. Otherwise looks to be in good shape.
Installed trans, but within a few months 3rd brake not working, and began slipping out of 4th.
Oil was silver.
#2. Pulled trans, shop warrantied parts and went through it again.
Installed trans but no change - worked the same as when I took it to shop.
#3. Pulled trans, shop found deep groove wore into 3rd/4th shift fork. Replaced necessary top cover parts.
Installed trans, within the year, 3rd brake not working, began slipping out of 4th, then could not shift into 4th.
Parked truck last summer.
I don't know transmissions, but have read the getrag manual a couple of times. Seems something is wearing out that 3rd/4th fork. Anyone know if a rebuilt top-cover will fix this? Or what is wrong deeper in the case? Sure could use some expertise here. Seems not too many 'good' repair options around these parts. I'm going to pull the transmission soon and have another go at it.
By "brake" I mean; when you pause just before slipping into gear, the gears mesh......well after a while when I went for 3rd it would want to just go right in with no resistance and grind. That seemed to be the 1st thing that went wrong, then after driving a bit more 4th gear would start gradually wearing out; meaning lever would begin to pop up (would not stay completely down into position where it should be); this would get worse and worse until it began to pop out of gear altogether once in a while, and then eventually would not stay in 4th at all. (On the positive side, I've got transmission removal down to an hour!.....and I did refresh the pilot bushing and release bearing. Clutch looks good.)
