Any experienced Jeep wrenches out there that can help diagnose a knocking sound in my 232?
I don't believe it to be rod knock but since I've never had a vehicle with it, I can't say for certain.
The noise appears to be coming from the oil filter housing area, where the distrib goes into the block and into the oil pump. It is a hollow knocking sound... not very loud but gets louder as the engine heats up. Gets quieter as the oil pressure/rpm drops... as in idling in gear. Oil pressure is 45-50(mechanical guage) at idle in park, 60-70 at 40 mph top gear, ~20-25 idling in gear.
Knock got fairly loud yesterday while driving around. Did an oil and filter change this morning and the knock is much better now, but still present.
Motor still runs smooth and strong... just like usual. Nothing else abnormal except that I don't remember the oil pressure being that high... at idle or at cruise speed... seems to be at least 50% higher than I remember.
Approx 1 week prior to the new knock, I did the GM HEI distributor conversion. It has run better than it ever did before. I used a wrecking yard distrib but replaced that tonight with a new one to rule out bearing slop in the used distrib. Knock still there.
I don't believe it to be rod knock for the following reasons:
does not get louder with load
pulling plug wires one by one on each cylinder yields no change in noise
knock got quieter immediately after an oil change
knock cycle is too fast to be in the lower rotating mass... sounds to be at twice the speed if not more like 6 times... too fast to actually count the number of knocks in a given time period.
I'll be checking the flexplate tomorrow as I've heard that a cracked plate can cause a similar noise, but I doubt that's it.
Any ideas?
Thanks,
Jim
Wylie, TX
Any ideas?
Thanks,
Jim
Wylie, TX
