I need help with a trailer wiring issue on my 01 2500 Dodge 4X4. As this is a new issue I have replaced the two rear 1157 bulbs (Stop and run), checked all of the trailer wiring, including the ground connections, and truck wiring.
The problem is the running and side marker lights stay on with out the truck lights on. (Somewhat dimmer) If I unplug the trailer plug the lights go out. If I leave the trailer unpluged for about one hour the trailer lights don't come on when I plug in the trailer wiring to the truck. But, if I reach inside of the truck and turn the lights on, the trailer lights stay on again when I turn off the truck's light switch.
Now. Using a test light I find two wires in the truck's factory trailer light plug with twelve volts. The battery wire and the running light wire. Anyone with any ideas? I unpluged the "Trailer" relay under the hood while the lights are on with no change.
