I've installed several dozen SB clutches, DD and single. I have a Double in my '03 3500 4x4(SDD3250), used to have one in my '96 2500 2x4 twin turbo, a single in my '97 3500 4x4. I've replaced several DMFs with Southbend's kits(G56-OFEK, single disk rated to 475hp), and every one of the customers has been happy as can be. I've heard some comments about grabbing with the DD, and can say with my '03, I don't like the way it launches sometimes. If you're never going over the 450hp mark, I'd say stay with the Single, which is what's in my '97. It's pretty stout for a towing truck, pushing 45psi boost fairly regular, and I've not had any problems with it. The '97 and '03 very seldom burn a tank of fuel without a trailer, so they tow quite a bit. The '97 has 85k on the ConFe, and the '03 has 35k on the SDD3250. My DD really does rattle a lot with the clutch depressed. Even had a guy tell me my throw-out bearing was out. I told him no, it wasn't, but he was a FULL-TIME MECHANIC, so he should know... ... .
(told him it was a double disk SouthBend and he just stared at me, and said "It can only be the bearing, there's nothing else that makes that kind of noise"... . )
The clutch in my '96 didn't gave up on me, but I was afraid to reuse it... . the input shaft gave and dumped shrapnel and oil into the front disk area... . not a pretty thing... . Probably would have been fine if I'd realized what it had done immediately and not ever pushed the clutch in to let the metal between the facings..... :{
Also, I believe all the G56 clutch kits come with the upgraded master/slave cylinder assembly.
