guys don't forget the marketing aspect of oil drain intervals. you got more than engineers writing the manuals, notebly those who are trying to inspire confidence in the customer that the engine is robust and requires little special care during breakin. the mfg is solving a different problem than you are -- they want to minimize your maintenance expense and inconvinience, inspire confidence in the vehicle, and make statistically sure the engine survives the warranty period. you, hoewever, want to find the point of diminishing returns just to make the engine last absolutely as long as possible.
That said I know of no oil change related ISB failures -- the darn thing is going to outlast you anyway, even if you make no special allowances for reduced drain intervals during the break in period!
Anyway, just remember that when you ask a mfg (incl cummins) about the oil change interval, you can bet that they have more than pure engineering in their heads. Its highly unlikely that they will recommend anything even close to a dimminishing returns procedure (such as changing oil very frequently) that most of us old school guys are used to. Hopefully they will answer a direct question such as "will I hurt my engine if I change oil at 1,000 miles"
Does anyone have any data or authoritative descriptions from a tribologist supporting the assertion that "wear particles" (pieces of iron) THEMSELVES are BENIFICIAL to the break in process?
particle sizes are very large at first, and go down in size exponentially as wear-in occurs. That stuff ends up burried inside the bearings -- after they scratch cylinder walls and rings, or become trapped in the filter. you want the parts to wear in evenly, not with scratch marks. Unrelated to engines, I don't know of any polishing process that uses dislodged substrate material itself as a compliment to the abrasive slurry to obtain a smoother surface. it gets washed off as soon as possible.
that aside, I admit I can't explain the TDI break in experience. you're sure this statistically this is valid, and not just anectotal? Do the TDIs ship with special break-in oil?
I'm out for information and don't mean to discredit anyones opinion. I'll admit that keeping the first oil in there a long time makes my hair stand on end because:
1. the additive package is depleted more rapidly
2. initial particle sizes are enormous and you need to change the filter early to positively guarentee they don't blow through the media and cause damage, or cause the filter to go into bypass mode.
3. sheer stresses are very high during breakin
4. instantaneous temperatures within the engine are very high at the points of extreemly high friction interfaces while parts wear into each other.
5. the only time I've seen a credible recomendation to "go the distance" on the first oil change is when there is special break in oil.
All that aside I've been guilty of overdoing it my self, but really, a couple of extra changes is cheep insurance. I Changed my 1986 Buick 3. 8L at 300 miles, put in a magnetic drain plug, and then went another 500 before dumping. you should have seen the pictures I took of that plug...
I'm suggesting drain intervals of, say, 1000, 3000, 5000, and 7000 for the first four changes. something like that. that will get you to 16,000 miles with essentially fresh oil and (so the old school goes) an optimized break in.
