With my original engine having 270k miles on it and getting a coolant in oil analysis from Blackstone I decided to swap in a low mileage used engine (junkyard,crashed truck).
The "new" engine received a new timing gear housing, PDR cam, seals/gaskets/filters/hoses before going into my truck.
I primed the fuel system as I've successfully done before but this one just wont start. Double checked pre heater, filter o-rings, rubber lines, lift pump, swapped relief valve, etc.
How far off with injection timing will cause a no start situation? I matchmarked the pump shaft/timing gear and it when back together to where it looks like it's in the same place figuring I'd have it close enough drive it to the diesel injection shop and have it timed properly.
When I first tried starting it I was getting some smoke out the tailpipe. Now after much pumping & cranking It's not even putting out any smoke. Cracking the injector lines at the injector results in fuel squirting out of all six lines (all over engine bay
I'm looking for more options/opinions but my current theory is that junk got into the fuel system while it sat in the junkyard and I've now pumped it into the injectors. Smoke at first/now nothing...
Do 12v injectors have a screen that can be cleaned? If crap did get into the injectors can a diesel injection shop clean them? (like Marren motorsports or RC Engineering for gas injectors)
Thanks, Eric
Thanks, Eric
