New Error Code ??
Need some ideas before I call a Ford dealer
Breakin in at 10K miles
I deleted the other short thread on this subject because it was confusing and it wasn't to the point.
My truck has 5500 miles and it runs perfectly - strong and 18 plus mpg (empty).
After startup and ten or so miles the gauges go dead (all except the speedometer). After a couple more miles all the gauges come to life and the 'engine' light comes on. It runs fine and doesn't miss a beat. If I cycle the ignition 3 times the odometer reads "P PCU" and the 'engine' light goes off. After awhile it will do this all over again.
H E L P #ad
I fear the dreaded dealership re-flash of the ECM. I don't want to lose performance or mpg. Thanks in advance. Joe
White 2001 QuadCab 2500 Laramie SLT, HO 6-speed, 3. 54 limited slip, Mopar exhaust brake, towing/camper options, Rhino liner, Grover Air Horns (not yet installed), Un BOMBed (so far), DUAL AIR BAGS !!
Gosh guys, I'm looking stupid here... ...
Well, it did it again, but when I was re-fueling I had some time, so here's what happened
It posted
P PCU
p 1694
p 1693
done
5563, the mileage
now everything is fine and it doesn't happen anymore.
Do you guys want me to go away #ad
Joe
PS what is 1694 and 1693 #ad
1693 indicates a fault code in the ECM and PCM.
1694 indicates a bus communication failure to the PCM.
You could try making sure the wiring harnesses are secure to the ECM and PCM. Since the indication is a bus failure that may be your problem. With that few miles, I'd let the dealer check it.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
I'm looking through my troube code list,and I agree with Alan on checking the ECM to PCM connections.
-Mike
