Dito on the gauges..... here we go on some others.....
Computer Boxes:
VA,VACPC, BD plug-n-play are all the same computer add on box. I believe this box just adjusts the timing.
PE - Power Edge, three level adjustable fueling box... can be customized.
PE EZ or Just EZ - a different box built by Power Edge. It adjsuts the timing and adds a small abount of fuel. There is a version of this box that DD (Diesel Dynamics in Vegas) sells that has a level on it for just timing.
TST Powermax - don't know much about these other than there are like three or four different ones and they are fueling boxes.
There are more. . I just can not recall them.
Injectors:
Disesl Dynamiscs makes a bunch of different ones, you will see them referred to as DD1,DD2, DD3. These are differnt levels of power. . basically bigger holes in them.
Bull Dog makes some too... . seen them as BD1, BD2... . you get the ideal.
275's or RV injectors are Bosch factory Manufactured 275 hp injectors. They are commonly used in RV's that have the same engine as our trucks.
I could go on about some other stuff...
DDT TC/VB that is the Diesel Transmission Technology Torque Converter and Valve body. . got an auto... . this is the way to go if you are going to add power... or even if you aren't.
Okay I am done. . someone elese turn
Hope this helps... .
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge,
SPA Boost/EGT Gauge on pillar mount, DDT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See
My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
