I've been reading the latest posts about modifying stock fuel plates and after looking at as many pictures of cam profiles as I could find I decided I couldn't do much harm by whittling down the stock plate on my P pumped 12 valver.
I had been running the stock plate all the way forward and the AFC cover forward also with the starwheel in the stock position. Slightly more power in the low rpm ranges than stock with a considerable belch of black smoke if I pressed the pedal any more than absolutely necessary to get the truck moving. Once the turbo spooled up I could reasonably control the smoke output with my right foot. The motor defueled rather quickly and was slightly less anemic than stock
. EGT's never went over 800. Max boost approached 32 psi in OD @ wot.
Chose a profile similar to a #10 with a rounded "foot" about 1/8" tall tapering quickly to 1/4" and using the rounded edge of the grinding wheel blended the rest of the curve to about . 060 above the flat portion continuing up to the top of the cam. Polished the grinder marks off with some 80 grit wetordry followed up by 220 and finished with 400 and buffed to a shine.
Installed the plate all the way forward and set the afc housing back on in the mid (stock) position.
Yowza!!!
Major difference in torque and useable rpm. Less smoke off idle--I attrubute that to the neutral afc housing--and it gets on the governor real quick in second and third with some nice smokey (black haze) push ya back in the seat pulls in fourth and fifth all the way up to as fast as I want to go in a 4x4 with stock brakes and suspension. Gentlemen I am truly impressed. After a couple of quick full throttle shifts in the peak of the power band I noticed the clutch starting to sound more like an unlocked torque converter so I pretty much have my next mod lined up for me. :-laf
After the clutch i figure a GSK and afc spring kit would be in order. Oh yeah i need to verify/reset the timing also. Further mods would be a set of Formula one mach 2's and delivery valves. By then I should be needing a larger turbo. As of now I am at 1100 deg. pre turbo and hitting a solid 37lbs of boost. Oo.
This is a blast!!!
I have been Bit!
So to anyone considering gathering up the grapes to cut your own plate I say go for it. Unfortunately I didn't take any pic's but if anyone needs a rough sketch of the profile send me a pm and I'll send ya my best artist's rendition :-laf
Yowza!!!
This is a blast!!!
I have been Bit!
