Engine/Transmission (1998.5 - 2002) Next engine survey, brief and simple
Engine/Transmission (1994 - 1998) When to do timing
Engine/Transmission (1998.5 - 2002) i.a.t sensor where is it?
1. . CARE
2. . CUMMINS FAN
3. . NEVER A FORD
99 QC. Sport,2WD,SB. autoK@N cone filter,275HP. RV injectors,custom 4"exhaust,roll@lock bed cover
CARE
Cummins - but want the solid axles, coil springs, long rear leaf springs, Dana/Spicer componants - the package (though needs rear disks and manual hubs)
WILL FOLLOW - if # 2 conditions are met/vr. close
1. Care
2. Cummings
3. Will follow
94, 5 speed with 3. 54 rear end, Gear Vendors aux transmission, 76000 miles.
1. Don't care, as long as Cummins is an option.
2. Cummins loyal.
3. Will follow to first Cummins/crewcab combo.
'93 W250, CC, 4x4, 5spd. , 4:10, Cummins w/ Mild mods, K&N, 16cm turbo, Custom straight exhaust, Lund visor w/lights, 5th wheel, Gooseneck, H. D. rear hitch-pintle and ball, Aluminum everything, Cobra 148GTL W/mods.
1 Dont Care... if its a CAT
2 Cummins (but the whole pkg is what counts... NV4500, Dana axles, etc. )
3 Follow Cummins... (But would question the Phords real closely... . )
96 2500 SLT, Reg Cab, 12V, 4x4, NV4500, 4. 10s, LB, LSD, Black Exterior w/chrome rockers, Camel/Tan Interior, Towing Pkg w/ electric brake controller, K&N Filter, Other Upgrades pending $$$$ :cool: TO THE BOMB BAY!!!!!!!
1. Care
2. Cumminsfan
3. Not planning on buying a new one #ad
'cause this one is going to outlast me! #ad
'95, 2500SLT,longbed, 5 spd. w/filter, 3. 54 w/Mag-Hytec cover, K&N filter,PacBrake,Rhino Liner, Amsoil bypass filter, Amsoil in transmission & Diff. ,Prime Loc, CAT-less (still stock)
[This message has been edited by crabman (edited 03-26-2000). ]
1)CARE
2)Both
3)a. guess I'd find out just how long this ol beast will last or,
b. Looks like there will be plenty of used Dodges to pick from if I I have to upgrade.
1)Care, I like the Cummins! #ad
2)Dodge Fan! The Cummins is a plus! #ad
3)Stay with Dodge no matter What! #ad
92 Dodge LE, Cummins, reg cab,4X4,3:54 gears, Auto, Black/w Maroon Int.
Care
Both
Dodge
Mack will be replacing their engines with Renault engines. I asked a guy from Mack if they were going to put Poodles on the hoods. #ad
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
Definately care! I still love the new Cummins, even though it is computerized and over valved! #ad
Would not have a V-8 or V-6 engine- must be inline 6!
Both: I am a fan of the Dodge truck, its superior running gear, and DEFINATELY the Cummins! #ad
Would like to see manual hubs, though!
Would consider following, but hesitantly. #ad
"Other" truck MUST also have: Solid axles, manual hubs, cast-iron cased transmission, and good overall design.
1996 White, Extra-cab, 4X4, 5-speed, 4. 10 Model 80 rear, Laramie Pkg, Rickson Truck Accessories 19. 5" wheels with Michelin XZT load range 'G' mud type tires, Full straight-pipe exhaust, Mopar brush guard, K&N air filter, removed turbo silencer ring, 'tweaked' injector pump, well over 100k miles, lots of GOOD, BLACK SMOKE!!, Rollin'-S 25-foot, 10 ton flatbed trailer, with Vacuum/Hydraulic brakes, 16. 5" tandem dual Dexter axles
1. Care
2. both
3. Cummins
99Quad4x4SLT,white,shell,rhino liner,r. boards,all options minus leather,"near"stock
Dave H.
I care
cumminsfan
will follow but to where, not going to Toyota Chevy is promotin this aluminum diesel waitin for a crack and Ford, well never mind guess i will have to stay.
99 white qclwb 4x4 5spd. no noise restriction devices hooked up unless the 3" pipe is considered. waiting on funds for Stage 3 injection services. And then waiting on Scotty to patent and finish his air supplying device for me to buy. Also maybe some other things down the road.
1. Care
2. Fan of both
3. Won't follow, too much bad luck with warranty repair on other 2 brands, plus phord doesn't have mechanics at any Kentucky dealership, just computer diagnostic monkeys
2001 Ram 3500 4x4 Quad Cab,all black(Sport pkg. ) Cummins24v, 5speed, 3. 54,all options including leather :D AMSOIL Dual Remote bypass oil filter,AMSOIL air filter planning to buy a Lance camper or 5th wheel
