Illflem, I was hoping you would chime in here!
Under normal conditions, I believe the vacuum booster should be able to hold enough vacuum overnight to handle a couple of brake-pedal depressions first thing in the morning. All of my vehicles which have had P. B. could do that, including this truck for the first few years I owned it.
But this condition is different, because that ability disappeared suddenly. Hence I think it is a vacuum leak which is affecting the booster. The leak wouldn't be in the hoses, since there is a check valve at the booster to keep it charged, so I would think it has to be either in the booster diaphrams themselves, (rebuild time) or in the check valve on the front of the booster. I am going to try to replace that check valve and see if it makes a difference.
