No cab heat
2003 won't track straight...
06 AC compressor fix. A coil kit is available
I am having none or hardly any in cab heat. The coolant temp is in the normal operating range, yet no heat comes through the vents. A/C blows nice and cold. Any thoughts on where to begin?
Thanks
Fill out your signature so we know what you are working on. Probably a blend door... ... ... ... ... ... have you verified there is hot water entering and exiting your heater core?
My truck just started this year blowing cold out of the 2 drivers side vents but hot everywhere else , defrost is also hot on all 4 vents. I guess theres a door that's not functioning properly, but theres the same amount of air blowing out of the vents as anywhere else. If I put it on recirculate it will warm up on driverside .
