2nd Gen Non-Engine/Transmission No Cruise Control on 02
2nd Gen Non-Engine/Transmission 2001 4X4 help!
Engine/Transmission (1994 - 1998) Torquing head studs
I have no cruise control, It was working fine then just out of the blue nothing not even the light in the dash will come on. The only code present is p1596. not sure if this is related or not. No other problems or symptoms ect related to a clock spring.
Any thoughts?
I have checked the connections and wiring at the control module and all look well there. I can't seem to find which fuse feeds the circuit or where it gets its power from. Anyone here that knows?
Thanks a whole bunch John... ..... :)A year later several threads on several forums and this is the first useable info I have gotten and it is exactly what I was looking for.
Is there a wiring diagram for this circuit I could see also?
Is this from a factory service manual on CD by chance?
Yes.
Send me a PM with your email address and I'll shoot a copy right over to you. The file is too big to attach here. I'll also send you the connector pinouts to help locate the correct wires.
It's from the Dodge Powertrain Diagnostic Procedures Manual on CD.
Best regards,
John L.
well was it your clock spring ?? my horn wont work in the position i drive in,,only when i move the tilt,,,the c c was the same way it ha s now stopped completlety,,who has the parts?? thanks in advance
When cruise went out on mine, the vacuum line that goes by the drivers side battery had corroded. Spliced a new piece in and works good. If all else fails you could check that out
fstfish66, since it seems things don't work with your tilt steering wheel check out any connector on the steering column/shaft. If you have connector on column tilting the steering wheel can and has pulled wires out of the connector.
