Yeah, you're right. Dodge is responsible because AutoZone and OReilly's don't stock off brand no name filters for your truck. Dodge is responsible because the independently owned and managed Dodge dealers where you live can't please you. Your truck won't meet the non-existent fuel mileage posted on your MSRP sticker apparently driving around at slow speed on ranch roads in first and second gear. It was Dodge's fault that you didn't call a dealer for a service appointment. It was Dodge's fault that you or some amateur screwed up the serpentine belt when installing an aftermarket water pump. And it was clearly unfair that Dodge didn't reimburse you for your screw up. Sounds like everybody you come in contact with owes you something.
EB, who was an ollfield hotshotter has put over 200,000 miles on his 2007 with no problems, my 2008 has almost 60,000 troublefree miles, and countless others are troublefree or have had only turbo or EGR cleaning and a reflash done.
Do the courageous thing, run straight to the closest Ferd dealer and trade it for a really fine, troublefree truck. You'll feel better . . . and so will I.
Just for your infomation, the reason I was trying to buy the filters from local sources was that the dealerships down here stayed out of them for months and months. I did not knock the sensor off during the install. Here is how it happened, the water pump started making noise and finally locked up while down at the ranch where cell phones dont work, that belt wrapped around the fan and ripped up the sensor, I still have the water pump by the way and it is a different water pump than the 5. 9. It was out of stock as well as the belt and sensor, I called every dealer in my area looking for parts to fix it, it was on national backorder, cummins in corpus christi had no water pump or belt as well. You guys like piling on and killing the messanger and braging about trucks who really dont work anything like my truck does, its not about how many miles a truck has, hiway miles and ranch offroad roads are not the same, plus look at where the truck lives and works, the edge of the Mexican desert starts in my area, tons of caliche rocks, dust and 120 degree days over 62 in a row at one time, this truck was not tested or built for these conditions, I should have known since it was the 1th year for 6. 7, but i was so excited thinking i would have a 5. 9 dependabilty with the 6. 7 LMAO!! I have owned over 20 pieces of HE and repaired and operated every one of them most of the time. I hope Dodge sells the Taliban some 6. 7's in Rams so they will brakedown or be out of service waiting on Genos to UPS parts to Kabul Afganstan and flys in the only sincere 6. 7 tech Mullenaxe to reflash them and keep them going!!!!!LOL Kill the messanger is the motto some have in here... .
