No Pullrite Super Rails for 2WD 1 Ton
Retrofit Gilde-Ride Hitch Pin Box on NUWA 5 th wheel RV's
Just Ordered a 6 speed - how much harder to drive???
Anyone know why Pullrite doesn't make a Super Rail kit for my truck? I assume its a clearence problem, but I'd like to know where. Also, has anyone found a way to make it work?
Thanks in advance,
Ken - I neglected to thank you for all the help your website provided when I was installing the Super Rails on my truck last summer, especially the tip on using the tape to test drill the holes. So - Thanks!
Scott
I'll still probably get the Super 5th hitch from Pullrite. It looks like one of the better ones out there. I had a Reese hitch I put in my other truck 9 years ago and it seemed to have a lot of movement around the kingpin.
I need an easy solution to leveling the bed height to the top of the hitch rails for when I need a level bed for hauling. On my other truck, I used some cheap flake board cut to fit, but it was heavy, a pain to store and started coming apart.
Heres another positive note on the Pullrite hitch. Install went very well and I have towed 10,000 miles so far with no troubles. The pins go in and out of the brackets with ease.
