No Start?
need help with PowerMax 3
Cummins in 2003
After driving about 60 miles today I got home and left my truck idling by my shop longer than anticipated, about 10 minutes, shut it down then tried to restart about 30 minutes later, no go. It was about 90° out. Tried several times over a ten minute period, nothing. Fuel pressure gauge was showing 22 psi while cranking, so it was getting fuel. I finally took a compressed air line and blew on the injection pump for a minute, it started right up and ran fine. Any ideas?
Bill,
If this is the same truck that had the spell on the road in NV sometime back maybe you need an exorcist. #ad
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Same truck Joe. Besides and throttle cable and return line this only the second time in 130k that it hasn't started in less than a second. It is my 2500.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
I have no idea what might be causing the strange behaviour with that truck. I might hazzard a WAG or two. Could something in the governor be sticking?
Bill
Did you check to see if the fuel shutoff solenoid was working correctly??
Larry
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
I agree ckeck that shut off selonoid. Had one go out on my 94 one very hot day in Charleston SC
'97 2500 4X4 club cab, BLACK, Leer XL-100,running boards , cup smoothie, EZ Drain, 103,000 miles
Wecome home Larry. My fuel pressure gauge is ported to the injection pump banjo bolt, I had pressure there so the problem must lie in the injection pump right? I guess that would include the solenoid, I'll have to wait and see if it does it again to check. Have to go to Lewiston tomorrow, hope it doesn't give up out in the scablands.
Bill,
You might burn some incense and have some sort of war dance. Maybe scare the evil spirits a little and they will let you alone. #ad
I had that problem with my 95. It eventually got worse. Sometimes it would start, sometimes it wouldn't. Next time it does it, leave the key in the on position and manually open the fuel shutoff valve, if it stays open it will most likely be the shut off solenoid on the top of firewall. That fixed mine. Hope this helps.
1995 2500, SLT Laramie, Xcab, auto, 3. 54, stock plate forward, 237K, Amsoiled throughout, dual by-pass filter, muffler and cat fell off, if you find them, there yours!!
1989 250, Cummins, auto, stock, work truck, 190K, soon to be Amsoiled
1967 Coronet 440, Steve Thomas built 360, auto, 2. 94, factory A/C, am radio, FAST!!!and is FOR SALE $5,500
1987 Celica GT convertible, auto, 67K
1989 Holiday Rambler Aluma-lite travel trailer
Amsoil Dealer
Is it possible to have it vapor lock inside of injector pump or one of the high pressure lines?
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
Asked a mechanic today he thought it mite be air. He said diesel wouldn't develop vapor.
But I would think if air was getting in it would happen all the time. (Said if air bubble you could use compressed air at bleeder screw to get things moving)
But shutting it down and not starting until air was blown on the injector pump(cooling it down) sounds just like symptoms of vapor lock. (Chrysler products were well known for it. )
Wonder if there was gasoline in the fuel the last time you filled up?
Could be fuel shut off solenoid mechanic said it could over heat (you can grab it to see if it is to hot) or get stuck and stay in on or off position. (compressed air cooling it off).
[This message has been edited by Missouri Mule (edited 04-28-2001). ]
