Noise
Trans. Temp. sensor location?
Rear crankshaft seal leaking??
I had posted a thread a few weeks back about a noise I was hearing that sounded like a wind noise but I was unable to locate it. I obtained several replies from members attempting to help and some very good suggestions. I checked, tightened and closed everything. Then I did it all again. I had suggestions from the fifth gear going out to heater hose problems and they were all appreciated and checked out.
Today I found the problem, and wish to share it with any and all members that might run into a simalar situation. It was the 4' Firestick CB antenna I mounted on a Firestick Mount that attaches/secures directly to already exsisting bolts and nuts under the hood of the truck just off the piller post. Its a great location and works great and now that I know what the noise is (its not that bad its just that a unknown noise gets the worry factor up) not a problem but I must say if it saves anyone the time I spent trying to find it then this post was worth it. And for all the members that tried to help THANKS.
Y2K RAM 2500 4X4 QC LWB Patriot Blue 5-Speed 3. 54 LS rear end, Trlr. Tow & Camper Packages, Westin Nerfs, Isspro Boost & Pyro gauges in a dual Pillar mount and DC Mud Flaps. Stock, ALMOST (so there is no mis-understanding, ALMOST refers to my Westin Nerfs & Isspro Gauges).
[This message has been edited by ldg (edited 05-11-2001). ]
If you want to get rid of that antenna noise here's an easy fix:
Take some twine and wrap clockwise along the length of the antenna and secure the ends with electrical tape. Then, heat shrink the area. Take a look at your radio antenna and you can see what the spacing of wraps should be.
You will have no more noise from that antenna #ad
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: JRE 4" Exhaust, Van Aaken, Practical Solutions Diesel Products:High Idler, Heavy Duty Idler Pulley, Intake Heater System Saver & HD U-Bolt/Anchor Plate Kit, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
<font color=36648B>2001 PT Cruiser Limited Edition</font>
As usual with this web site an answer for everything and someone willing to share it. Thank you, Bigdaddy I most certainly appreciate the information and we will do that. I had never given a thought to stopping or correcting the noise but we sure will now. Again, Thank You.
