I have a 2005 with the NV273D electric shift transfer case.
The shift motor stopped working and I replaced it with a new OEM unit and new ends on the wiring harness. New shift motor works fine hanging under truck plugged in but not bolted on.
Transfer case shifts fine with crescent wrench underneath but maybe a bit stiff. Truck does have 300K on it. Put new shift motor on and it shifted the case once in the shop then locked out leaving me stuck in 4x4 high range and the service 4x4 code on the dash.
At this point I thought maybe the resistance of shifting the transfer case was too much so out comes the transfer case and I take it a local gear shop I trust. Shop forman moves the transfer case with a crescent wrench and thinks its okay, but we still split it and inspect it. He finds it all fine inside, nothing needing replacing.
Local Dodge dealer willingly brings in another shift motor for the transfer case and I return the first one. We think we are all fine at this point but alas putting everything back in truck again the shift motor works fine hanging off the harness (supported by a block) but after aligning the position and bolting it on the newly reinstalled transfer case ... still no good. Transfer case shifted once and then locked out setting up the service 4x4 light and leaving the truck in 4 wheel high again.
What am I missing here?????? Harness issues maybe?
Any suggestions more than welcome. Thanks..
