So Don,Tell us how ya really feel!!!!
What I do not understand here is really quite simple,,IF you have SO much problem with their product then WHY use it in your truck at all????,,Also,the Castrol lube you so highly tout is used in more application than JUST the NV4500 so i'd love to see where you got the info that its a "specfic" lube only designed for the NV,,As far as the rest well its like this,if you feel and really believe that Syntorq is the only lube then by gosh use it,no one here is going to stop you,,I have used Amsoil's products in all my vechicles because of their ability protect under any condition I have put them thru,,I use them in my personal vechicles and both of my race cars(drag car and sprint car)and have seen their benefits over and over again,,So,with the signature you show answer this for me,IF all the parts you list at the bottom,and by no means am I questioning it, are on your truck and its OBVIOUSLY more than stock,WHY would you want to use a lube thats designed for a STOCK rated truck?????,,Wouldn't you want a lube that already proven to protect and handle what you have and is doing the very thing ALREADY in your truck??,,See I have seen the benefits in teardowns for maintence with it and have seen dramatic differences over other "snakeoils" in high HP applications,,TESTS,you say,I say test this,,ANY ONE(no disrespect here Joe D) can make a gauge,instrument or printout sat what it wants,my test grounds are real battlegrounds,,From a little stock Durango and my Ram,too the race cars I'm involved with its all the same answer,AMSOIL,,It has nothing to do with schemes,pyramids or marketing stratagies,just plain old fashioned seat of the pants hard work and REAL everyday tests,,Bottom line is this,its your truck do what you want,mine however will use it,NO MATTER WHAT DC SAYS,I've seen the results of high hp and torque applications of this lube and others and no others can even remotely compare to its ability to withstand heat and wear problems,,Your truck your choice,but don't tell others that have seen the difference it will not handle the job... ... .
