Engine/Transmission (1998.5 - 2002) nv5600 reverse surge then slow clutch pedal return
2nd Gen Non-Engine/Transmission Dually fenders cracked
I have been experiencing a strange phenomenon with my NV5600 transmission.
The problem only occurs when the transmission is at full operating tempeture.
When I shift into reverse, the truck feels like it want to take off backwards (a very strong pulling feel) even though I am only idling. It is hard to describe what I am feeling, but it is not how is normally feels.
Following this "surge" when I shift back to neutral and release the clutch pedal, the pedal appears to rise slowly (I have the urge to pull the pedal up with my toe.
Particulars:
bone stock 2001 HO
milage 76000
change transmission fluid three weeks ago before a 900 mile tow (6000# TT)
Mopar transmission fluid
I have also been experiencing grinds when going into reverse or a distinct clunk.
How was the condition of your fluid when you drained it?
Did you pull the PTO cover completely off and take a look inside, or just the bottom bolt to drain it?
Did you get all 9. something pints of new oil back in?
The situation started after the fluid change.
I removed the PTO cover and filled until it came out the fill hole. The fill was probably somewhere between 8 - 9 pts given some spillage (i don't have a Jays-EZ funnel YET).
The other change is the towing I have done since. I didn't notice the problem in the week between doing the oil change and doing the 900 mile tow (Interstate 81 through PA to MD). Lots of hills doing 65-70 mph.
I am not an expert but it sounds like your clutch is not releasing completly. This would cause the grinding and the surge. You stated that the clutch is slow to return, I would look at hydraulics first. It could be hydraulics or a sticky clutch.
Just my . 02 cents
