Observations with synthetic oil
Old 4kw Onan RV generator
1986 W100....engine swap questions
I have a story/lesson going the other direction. In the early 80's I purchased a 1976 Chevy K-20 that had about 70K+ miles on it. The seller said it have Mobil 1 in it. It burned oil and after a couple years I pulled the heads off the 350 and took them in thinking it was valve glides and seals. Nope they said the heads were fine. So I took them back home and put them back on a block that still showed the original honing in the cylinder walls, as I did not want to go deeper into it just then. A year or two passed and I pulled the engine, ran a ball hone in the cylinders and lightly used a ridge reamer on it, installed new rings and put it back together. Broke it in again and no more oil consumption. So I believe the lesson is the original owner switched it to Mobil 1 to early, and the OEM rings never seated.
I had to add a gallon of oil to my '00 Freightliner when it was around -30* outside... The Delo 15W40 was pouring out of the jug like molasses and I even had to hop back into my pickup to warm my fingers while the funnel was draining!! Several minutes to add a gallon got me thinking.
The worst part is the old Detroit 60 Series cracks off at high idle, and I'm pretty sure the oil filter bypass is open for quite a while when its that cold!!!
The 350 8V71 in the Titan 90 Chevy I drove for 3 years used oil like the old alcoholic uncle everyone has in their family, puking some of it and burning the remainder.
I damaged a couple of old Cummins engines back in the day with thick oil and cold temps. Now when someone walks by with an ice cream cone I plug my stuff in:D
On Linux, the ° symbol is created via <RIGHT-MENU> o o, pressed/released in sequence. Similar for ™ (<RM> t m) and © (<RM> o c), résumé (<RM> ' e), würst (<RM> " u), el niño (<RM ~ n), and como ça va (<RM> , c), € (<RM> = e), — [emdash] (<RM> - - -) ± (<RM> + -), Æsop's Fables (<RM> A E), Scheiß (<RM> s s) and many others.
Search for "macos symbol shortcuts". Windows seems to generally require one to memorize a large table of numbers.
Alt-248 will give you the °
Alt-241 will give you ±
Alt-230 will give you µ
You have to use a number pad, not the numbers at the top of the keyboard.
Speaking of synthetic oils....this is a new one to me.
Most of you probably know I'm a little skeptical....but am interested in your observations/opinions. They've been around a long time, not as long as Schaeffer's but a long time none the less.
http://www.synlube.com/synthetic-motor-oil.html
Very interesting.
150,000 miles in the 2,000 hour interval would be a 75 mph average o_O
I can't seem to find a data sheet on the oil, but the website is not the best.
Their oil filter does have some pretty good specs thou.
Very interesting.
LOL, that would be something. I interpreted it as "up to" one or the other, whichever occurs first.
It's funny though, they claim less than a penny a mile operating cost but fail to say over how many miles....
Over the 150,000 miles at a penny a mile they claim that's ummm, astronomical!
Yeah it should be whichever occurs first, which is why the 150K miles isn't obtainable on a diesel. Even on a gas engine at 3,000 hours that's a difficult to obtain 50 mph average.
Very interesting.
:D
