Originally posted by Ghostroller:
... Before we cut the external wrap off the wiring harness does any one know if a wire transfers mileage information to the odometer and what color it is? ... do any of the on board computers store the mileage reading and can this information be retrieved to correct our nonfunctional odometer?
The PCM stores the actual total mileage and the trip mileage. Upon key-on, it transfers this info to the instrument cluster via the CCD bus. Once the cluster is talking to the PCM again, it will display the correct data.
The CCD+ and CCD- wires from the inst. clust. are
VT/BR and WT/BK, respectively, to 'joint connector #7'. Between there and the PCM, they are VT/BR and WT/BR, changing to VT/BK and WT/BK, respectively.
(CCD: Chrysler Collision Detection; a data bus used to transfer information around the vehicle. )
If the CCD bus was disrupted before the inst. clust. , I would expect it to work erratically. I. e. , the speedo would be jumpy, the tach should be jumpy, other gauges would be similarly flakey. If all the other gauges have been stable, and *only* the odo was failing, I would tend to suspect wiring/traces internal to the instrument cluster.
As to the mileage, the PCM stores it, regardless of
whether the inst. clust. displays it. When you get the display working again, the correct mileage will show up.
This is all according to the SM. And they've been known to have misprints. And errors. But this is generally how the system works.
Fest3er
