I got a tip from a lifetime trucker friend of mine that I tough TDR members might be interested in trying. I just did and it work for me.
I was discussing oil change with him and I mentioned that because of the filter location and this being the time I'd ever done it on a Cummins, it might get messy but I'd read on this site the freezer back trick and was going to give it a try. In his ol' Texas boy drawl here is the answer I got "That's Bulls**t!"
He went on to say that all I had to do was get the oil hot, loosen the plug so the oil will drain but don't take it completely out, remove the filler cap from the valve cover and loossen the filter with the strap wrench to the point that I could turn it by hand and then go have a beer or two while the oil drained... ... .
"When you get back, remove the plug to make sure all the oil has drained. Enough oil should have gotten sucked out of the filter so you can remove it without no bag or gloves and without spilling a drop, works 9 time out of 10", he said. How about the one time that it doesn't, I asked? "Sucks to be you" was the answer!
Well it did work. About 1/4 of the oil was out of the filter and that allowded me to tilt it and get it out , no mess. Have any of you ever heard of that trick? As I said that was the first one for me and it worked like a charm. If some you of try it, I'd like to know how it turned out. Maybe the old man is on to something, but blame it on him if you make a mess
Rotella and Fleetguard strat. in case your wondering... .
BFC
BFC
