oil drain pan
Thermostat Block Heater Cord
A good compromise tire
I use a blow molded platic drain pan made by Wedco, it has an open top, pouring spout and lifting handles, holds about 14 litres. Wedco also makes plastic jerry cans, I got mine from Canadian Tire. Have seen similar ones made of metal, brand name was Brookins.
Neil
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): <bombedcummins@sympatico. ca> (link at top is work adress)
I just park mine over by the well and fishpond. I pull the drainplug and let it run out in the dirt. This way the fish stay regular and it makes our wellwater work in our oil lamps #ad
Just kidding... ... no, really, just kidding
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, yada-yada-yada
www.fostertruck.com/cummins
Larry,I also used to drain my oil into the well head. Had to stop when the old lady said her whites weren't as bright as they used to be. A side benifit is weeds no longer grow in the area.
I use a plastic dish pan my wife tossed out (of the kitchen) many years ago. The other vehicles are easy to handle, but the truck fills it nearly to the brim. I transfer contents to a 5 gallon plastic pail and when full haul to the local auto parts store for recycling.
*JE*
