Oil Drain Plug Removal
Losin a little coolant.
Installing US Gear Overdrive
I've had my dealer do the last few oil changes, today I attempted to do one myself.
Not did have much luck, though. I assumed before crawling underneath the truck, that the drain plug had a standard hex head. It doesn't. Does any one know the size and type (Alan Wrench?) of the OEM drain plug?
I will be replacing is with Geno's EZ Drian plug.
Thanks
Forgot to put my signature on.
2001. 5 2500 4x4,QC,LB, 4 months old 16,000 miles, ETH/DEE, SLT+, Agate Leather, Flame Red, Towing and Camper Groups, Clearence Lights
It takes a 3/8" square drive like a socket wrench or breaker bar. If you don't use a higher quality one it will sometimes twist the square drive on the wrench before the plug breaks loose.
Just drill some holes in your Geno's EZ drain at about the same spot as OEM. I just installed mine. I check to see if I have them in the right spot when I change the oil and report back here.
When I first got my 2001 truck I ordered a Geno's Drain plug replacing it for the factor one, it will leave about 1 quart of USED OIL IN YOUR OIL PAN AT EACH OIL CHANGE. THE EZ DRAIN PLUG WHEN INSTALLED BLOCKS THE 4 DRAIN SLOTS AT THE BOTTOM OF THE DRAIN HOLE!!!!!!!! When you take your plug out take a look at the threads there are 4 slots located at the bottom at 12/3/6/9 o'clock. Just use a GOOD 3/8 drive Ratchet works great. GOOD LUCK
2001 2500HD Quad Cab SLT LWB, 4x4, Cummins, 3. 54 gears,
Deep Garnet Red, Agate, 4w ABS, tinted windows,
Camper and Trailer tow packages with trailer towing mirrors,
HD transfer case, snow plow prep, cab lights, travel conv group,
mopar nurf bars, Downey SST cover, Bed liner with fifth wheel hitch
Power driver seat with power lumbar,
loaded loaded loaded!!!!!!!
