Baldwin is owned by Clarcor (sp), parent company of Parker. We have done a good bit of work for Parker over the years up in Cleveland.
So Yes Ron, you are right! A Baldwin is a repainted RACOR.
You "need" that cap tool and it's a "must have"? Really???
I've never had one or used one and I never spill a drop of oil removing a full oil filter.
I don't do anything but unscrew the filter and lift it out, easy-peasy, no mess at all.
And, all the benefits of that rust proofing the bottom of the truck gets from the blow back...My 2018 has a nice OEM "funnel" under filter drain pan that makes one place to position the oil catch pan. After I removed the "free" dealer installed rag out of it from the first oil change...
I don't see what the fuss is about. Take the filter out through the side letting it drain out in the OEM drain pan and the truck will stop dripping in a day or two.
And, all the benefits of that rust proofing the bottom of the truck gets from the blow back...![]()
Thank you!!!
so that brings the question again, NAPA or Donaldson for example are they repainted?
It is very odd you are dead set on this![]()
