I was in town 2 days ago and left truck runing, went into store came back out and found that I had no oil pressure registering on dash gauge, yet truck was runing fine,the oil idiot light was not on so I dove home about 23 miles on the way I noticied the pressure gauge would fluctuate form 0 to 40 so I took it easy. I figured the sending unit went out so I replaced it and put a mechanical gauge on also, to be on the safe side, changed the oil which I had planed on doing anyway, started her up and had good oil pressure I thought everything was fine untill today. I went to town and noticed the oil pressure had droped to 25 at idle from 40 and 40 runing, 45 cold. Is there any thing other then cleaning the pressure regulator I should look for? Is this a signal of the oil pump falure? Has any one else had this problem? Thanks for any help in advance guys.
