Had a '91 in the shop a couple years ago with a bad oil pump idler gear. Turns out the dowel pin fell out, took out the idler gear, which resulted in the pump to stop turning. Surprisingly, there was no damage to the engine as it was shut down seconds after the zero oil pressure condition. Also, there was no broken gear case. Just a damaged idler gear, and a very worn spot in the gear case.
