oil relocation kit
8.4 radio problems update?
Whats the deal with the BOSCH CP-ISB21S3 pump?
Herman8r
Hi All. Just pick up my 2021 3500 4x4 Laramie that I ordered in December. Awesome truck.
Looking at the oil filter...looks like a pain to remove without making a mess. I have used the Zip Lock Bag method in the past so this might be an option.
I was looking at the PacBrake oil filter relocation kit. Looks well built but a lot of $$
Any other options available??
HJR
The O/F plug that Geno's sells makes for an easy oil change. I was using this prior to adding a remote/bypass O/F setup. With the plug, it allows you to seal filter and turn sideways to remove, then fill new filter and seal. I had enough room to remove through cutout of fender liner. Never tried the top removal method but see that as a good option also. The main reason I went plug versus the bag was the handle made into the screw in plug. Enjoy that TRUCK!!! JM2C
I was looking at the PacBrake oil relocation kit. Looks well built but a lot of $$
HJR
I would highly reconsider doing so. Jacking around with the lubrication system could certainly increase your chances of a warranty rejection in the event of a claim.
What is your anticipated annual mileage?
Thanks for the tips. I messed up on my post title by not adding the word "filter" --- "oil filter relocation kit"
I like the idea about the filter plug. Also, good advise on NOT adding the kit regarding warranty.
I was thinking along the the line that the PacBrake is $$$. but looks well made. And the fact that I may only drive 10K to 15K miles a year...it should not be a big deal following the great advise from everyone.
I think the "Change oil" notice said 10K miles. I will have to look in the manual.
I will look at the air box regarding removal. I was not hard on my '06 to take it off.
The one thing I like is the CP3 pump. I was worries I might have the CP4!!
I crawled under the truck yesterday (only had it a couple days) and noticed how nice these trucks are. This truck rides better empty than my 2500 '06 did!!
Thanks again for the advise.
HJR
OP do a search for this, you will see how easy if your truck is similar it is to change from the top. No special tools required. also gives you a chance to check on the turbo. I also found a boost hose that was about to blow by doing the from the top change. Zero cost to do this method.
"EASY! Cummins 6.7 2013 and up oil change"
I have the Amsoil dual oil filter on my 04.5 . I will be selling the truck wondering if I should take it off and install on the 2018. Where are guys mounting them. I had a machinist make me the threaded adapter so i can run the Cummins filter.
Honestly p-Bar I do not believe a bypass system is necessary on the ISB's. Simply put they are "easy" on oil. I have many UOA's from my gen 2 which had a bypass filter, they are very comparable to my 14 without.
My 05 had a bypass and my 18 doesn’t, and I don’t plan to add one. I just don’t think there was a tangible benefit to it. The 18 is also easier on the oil than the 05.
I just watched the video. Funny thing....a Chevy Truck commercial ad came on just as I opened the video!!!
Video was a great help.
I like the plug idea!
Thanks again for the info
Changing the oil filter is easy compared to the fuel filters the top one you need about 18" in extensions a universal and a 29 mm socket .Go from the top . Barely any room to work in a PIA ! The filter underneath which the engineers put right over the drive shaft is a joy . went from a simple spin on to a cartridge , More fun. The petcock does not drain the housing completely , be sure you have something to catch the rest in the housing . Genos sells nice billet aluminum cap for the top filter housing . Makes it much easier to remove than the factory plastic lid . I found when you turn the key on to fill the filters look at that time to see if they are leaking past the O ring . Much cleaner than starting it and finding out the hard way. As others have said buy a cap to screw into your oil filter much easier than the baggy . Thank god it is only once a year on average .
