Oil Sending unit removal problems
How Many Miles?
There oughta be a law...
I'm having trouble removeing the leaking oil sending unit from my 96. Haven't found a tool in my tool box that will fit it. What size is it, Metric or US? Do you have to remove the power steering pump?
Thanks for any help.
retuttle@home.com
Here is how I replaced the sender on my 96. I bought a 1 & 1/16 "sender socket" from the parts store for about $10. I used a hole saw (about 1") to cut a semi-circle out of the edge of the left wheel well liner about where the top of the spring and the bottom of the shock tower meet. Then, using a couple of extentions on your ratchet, insert the extentions through the cutout, attach the socket and remove the sender by ratcheting from the wheel well.
There might be a better way but that's what I came up with at the time.
Bob
Thanks, I got the job done. Sure helps to have the right tools. I didn't know they even made a tool for that job. Now the next project is replace the fuel sending unit! Haven't figured out how I'm going to get the fuel lines off, I guess you pinch them and pull them off. Thanks again for your help.
Bob
The Dodge engineers chose to use a 'custom' sending unit that will require a special deep socket. A standard deep socket will not fit due to the oval electrical connector configuration at the top of the sending unit. I found a socket at Carquest for 7 or 8 dollars that worked.
Seems to me that a standard Echlin sending unit would have been fine, should cost about 12$ not the 45$ that DC wanted for there custom one.
I replaced mine about a year ago.
Redram
