Ok...370's on the way how hard are they to install ?
Turbo Housing
Fuel mileage question
Hey well I finally made another step my freind Blackdog finally pushed me over the edge I getting left behind his 24 valve and I'm not gonna stand for it!!... LOL. . So how hard the is the injector install? And, do all 94 have the low rpm stumble or just some? Mine as it runs now is very very snappy compared to other 94's and 95's and very snappy compared to the 96's and 97's with the larger cam in the pump. I did go with the Diamond B's and I was told by Doug up at Dave Mitchell's place just to do the injectors first and then proceed with what needed done. Does that sound good to you guys. Right now the truck has a Big cam plate, HX35 and a 16cm, and a few other mods that Dave has told me to do. The truck as it stands now will do about 38 to 39 psi and bury the the pryo if I stay in it. It seems the truck is running out of fuel at around 3200 + and that is where I am coming into the heat problem. Will the 370's help? do they have a better spray pattern? How many spray holes are there compared to the 175's? What should I look for if my truck is doing what it is already on the guages?? Well thanks a whole bunch everybody in advance you've always helped before! Be Good. Ryan
1994 2500 Regular Cab Longbed, 4x4 Red & Silver, Stainless Steel Rocker Panels, 2. 5" Skyjacker, tweaked afc & pump, BIG plate, HX35 w/16cm housing,no muffler or resonator, 16. 5x9. 75 Weld Rims, 33x12. 50 BFG Mud Terrians, 60 psi boost gauge, pryometer, J&J Stainless Steel rear 10" drop bumper w/backup lights, Westin pushbar, PIAA 90 Pro series lights, Weatherguard toolbox 27", Aluminum bed rails & tailgate protector, President Lincoln H. A. M. radio converted, 400 watt linear, Premier Pioneer stereo, *COMING SOON* 370 hp injectors,
Smokin:
You may need delivery valves as well to allow the injectors to work in better harmony with the pump.
Are you running 15. 5 degrees of time/ (Pumps mods... )
I might spend some $$ on the HX 40 fast to cool the egt's.
Sounds like your on the right track for some add'l smoke and ponies.
Have fun and don't over egt your poor "sickly" ram, to steal a Dr. Donnellyism.
Andy
Andy, Thanks for the reply, I was looking into getting the delivery valves which I know I will need, I was just holding out to see how big of a set of delivery valves I will need. I am thinking of running more like 18 degrees in timing? I know many, many people look down upon that in here, but, I have been told from many of the people in the area that they run well there. We do quite a bit of sled pulling in our area, you only have to if Dave Mitchell and Van Haisley are within an hour and a half from the house!! You can see some of our pulling pictures on Local and Regional events dicussion forum under truck pull pics!! I hope to see some of you out at MUNCIE, INDIANA for the meet up at Dave's Diesel!! Well I'm hoping to get these injectors in before the truck show up in Lima, Ohio. I have to go pick them up tommorrow. I will post results without Delivery Valves for now. I would still like tech info if anyone has any? Be Good, blow smoke!!
LMAO... like Smokin Cummins said, I've been on him to put them in for quite some time now. I think the early pullin season has finally got him in the mood, it's a bout time don't you guys think??. Take Care!
Test Mule for DMZ Performance
2001 Black 24v Cummins, 3/4 ton, QC, SWB, 4x4, Auto, Every Option Available, Agate Leather, 2. 5" Skyjacker Lift, 33x12. 50 BFG Mudders on 16. 5x9. 75 Weld Super Single II's, White Face Guages, Isspro Pyrometer, DiPricol 60lbs Boost guage w/ tattle tale needle guage on Dual A-Pillar, Cobra 29 LTD Soundtracker Nightwatch CB, Westin Chrome Brush Guard, Chrome Rocker Panels, 4" Chrome Tip, Dee Zee Diamond Plate Toolbox, Bed Rails, Tailgate Protector, Drawtite Removable Gooseneck Ball, Straight Piped, Silencer Ring Removed, K&N RE-0880, HX35 w/ 16cm Housing non-wastegated, JVD, BIG Custom Injectors, Pro Torque Convertor, Performance Custom Valve Body, Shift Kit, Holley Pro Lift Pump, Custom fuel lines
"Dodge Makes It, Cummins Shakes It"
#3 Dale Earnhardt Forever!
Larry, Thanks for the reply, I have a RE-0880 on the way right as we speak. My exhaust as it is said in my sig, is straight no cat no resonator. I installed the 370's today!! I haven't gotten to drive the truck probably 10 miles now but it seems very responsive, and makes my 16cm housing scream! I like them so far, but, it has a tiny shudder at low rpm, I'm thinking that it could be from the small delivery valves. And Larry my timing is still stock, so I can cool it down that way too. Thanks for the replies you guys. Be good.
Smokin
If you are overtemp on EGT now, the 370s will only add to the problem by adding fuel to the fire #ad
You need more air first. I see no intake or exhaust mods in your sig so I'd say you need a K&N 0880 and 4" exhaust at least. With the kind of fuel you'll get with 370s you may need an HX40 also. This should push you over the stock clutch holding capacity too(if you have a 5sp). one thing leads to three others. #ad
My free advice is worth every penny #ad
Larry
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
I've got a friend with a 12V that wants some 370's. Where is the best place to get them and about how much are they?
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, BD 2LO kit, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HX-40 Turbo, HOT Power Edge, PE EZ, Bully Dog Stage III injectors, South Bend Ceramic Puck Clutch, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), Bar II Brush Guard with KC Daylighters and Fog lights, Ultra-lite guages with blue bulbs. </font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455&f=0" TARGET=_blank><font color=red>New Pictures of my "White Obsession" and Dyno Run</A></font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423" TARGET=_blank><font color=green>BD Dyno Days 10/28/00</A></font>
<font color=purple>
NRA Life Member! (Need to protect our rights and FREEDOM!!)<font size=-2>
[This message has been edited by BIG BOB (edited 05-21-2001). ]
Have you test the fuel pressure after the filter? You may not be getting enough fuel to the injector pump to feed the 370's. You need all three-exhaust-fuel and air to make the cummins work.
fuel pressure should be around 20psi @ idle & 30-35 @ 2000 rpm. (after the filter) #ad
97' 2500, 2x2, 5spd. 330/750TST,afc springkit,silencer ring & kitty missing,K&N, straight pipe Luk Pro Gold clutch (John Deere hauler)
