That is not so
I am using a Preporator. The predicessor of the Airdog When I first installed it I had all sorts of driveability issues. Charlie Ekstam the inventor of the Preporator and the Airdog,We had many conversations about the problems. We finally solved the problem by opening up the line into the tank. It was his suggestion that the intank module was too restrictive.
While it is true that the factory suction tube is not the best it has been proven more than adequate when used with the AirDog. The AirDog engineers took into account the factory tube and made sure their product would not suffer adversely because of it. Don't know how, it just is. Putting a Vulcan draw straw in is mandatory if you are removing the in-tank pump (unless you have the factory module) and/or with certain aftermarket lift pumps. While you can install the Vulcan with the AirDog to me it is not worth the hassle of dropping the tank.
Godspeed,
Trent
