One more thing about transfer pumps
Shifting Without the Clutch!?
new 24 valve on ebay
I just changed out my lift pump last night. For anyone who is going to do this, be sure to remove the fuel filter, it makes the job MUCH easier. The pump I put in came from Cummins for ~$135. 00. My old pump read about 5 psi at idle, I did not do any checking on the road. The real problem was that the pump took for ever to refill the filter housing after a filter change and the pump sounded like a box of rocks. After I changed out the pump I took the old one apart. Clean as a whistle! no wear no nothing. The motor turns very stiff and with a ratchet action which could be from being a PM motor. Anyone out there have a dead pump that they took apart and found the actual pump to be bad?
PS This is my first post!!
'99 3500 QC, 4x4,5 speed, Intense Blue, 275's drilled air box, silencer ring MIA, Geno's M-E pipe.
Welcome David!!!
01 2500HD QC,SB,3. 54,5 spd,4X4,241HD,SLT+,Sport all black,fully loaded,all leather htd,jacobs e-brake,tow pack,camper pack,,full rhino lining bed and rocker panels,265/75r16 BFG ATs ko,nerf bars,everthing black,4'' Jardine,ultra lite pyro & boost on a-pillar,EZ,NO stickers except cummins on door,License plate-1 CUMN, NRA endowment life member
Hi David. I replaced mine but didn't take it apart. I still have it so I may take it apart and look at it. I didn't even check the pressure on mine. It started cutting out so I replaced it.
welcome!!
i think i have a lift pump problem. i've done some engine mods:banks powerpack,275 injectors, and now the van aaken cpc. the truck runs fine till i plug in the VA then it rins like its running out of fuel! i think ill be changing my pump soon... james
1999 RED LOADED 3500 QC DUALLY. 331N. DUNLOPS,ALPINE AUDIO,PSYCHOTTY AIR WITH K&N,BANKS POWERPACK,275 injectors, VA CPC, soon come. . DTT TC and VB. more in store????
Ramhead,
I wonder if you're getting restriction on the banjo bolts with the VA box? Are the fuel lines stock?
Charles
2000 QC 2500 4x4 LWB ETC 6 Speed Anti-Spin 3. 54 Trailer Tow, DD1's, Practical Solutions boost module
1969 Toyota FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
