Overhead gauge pod installed
step bars
Ice Storms and Frozen Doors ..... and a lesson
Well I thought I would give it a try and I like it! Took two of us about four hours but we got it in there, whew. We still have to install the sending units for the gauges but tomorrows another day!!!
How will you get the wires down through the drivers side post and out the firewall. I am new at this but I think your pod looks great.
Mike
did your Di/Pricol trans. temp gauge come with a wiring harness? just got my gauges and no wiring diagram . three prongs on back of gauge and don't know which ones to use for what. thanks mike
Mike
No problem with the wiring, take the cove roff the post there are two bolts holding it on, then work it out of the dash
-Ken
Mike
I did not make the cut because the overhead computer would cover the top of the gauge from my sitting height, a shorter person might be able to do it. You would have a slight gap under the headliner at the top if you dont cut it
-Ken
How is it driving at night with those up there? I have some night vision issues and usually wind up turning down the dash lights during long drives, I like the looks of the gauges, but wondered about it blinding you at night, or when you are looking out your rear view mirror.
Did you have to move the mirror, and was the mirror wire long enough, or did you have to run it through the pod housing?
Looks great,
Thanks in advance,
Dave
No problems at night the gauge lighting is fine, the mirror is ok, but for my height it could be lowered a pinch but I have it adjusted so I can use it, the pod fits in there snug you can take about a quarter of an inch off of it if you want it to fit absolutely tight to the headliner, all in all like it!
-Ken
