Overhead gauge pod installed
step bars
Ice Storms and Frozen Doors ..... and a lesson
I didn't have to remove my console or headliner. The pod was able to slip up in between the mirror and the console and I just tucked the wires under the leading edge of the headliner.
BTW if you use the clearance light wires for the lighting they won't dim with the rest of the gauges. I found it hard to look out the mirror when the gauges were bright.
Im glad to hear others had a problem with the lighting on the pyro gauge. I thought I did something wrong :D
EGT -LED wirin??
Does anyone know if the LED for the EGT(pryo) can be hooked up to the same 12v dimmed as the lights for other gauges(boost back lights)???
