Fletcher said:I would like to recognized this as my first serious post, yehawww! Oo. :-laf![]()
So as of right now you're 1 for 185. Sounds like good odds to me
-Scott
Fletcher said:Ok, I’ll try……… The pump criteria is complex. It’s base from all the ISO standards (temp, injector, lines, fluid etc,) The flow duration is measured from ISO injectors opening a 1000 times, each will be tested then, an average percentage will be established for your cc.
mayby some of the SME's (subject matter experts) can elaborate... ... ... ... .
mjoppie said:well fletcher, im honered that you used it up on me. i think i know what your talking about now Oo.
thanks a bunch
matt
JoshPeters said:As long as we're on the subject of pump output..... What do our trucks put out of lets say a stock 180hp pump when they are maxed out..... and what does it take to get to where lets say Kent Crowder is at? 450cc's stock, 600cc's for Kent?
Josh
nascar mark said:Comes down to how much money and time you want to spend on the flow bench with a good tech.
nascar mark said:Kent's pumpwild guess 2000cc's. Mind you it's not a Dodge/Cummins p7100 either.
Sled Puller said:Holy cow!!! 2000 ccs!!! What pump do you think it is??
Is it fair to say 1cc per HP?
Sled Puller said:I don't know about the 1cc per 1 HP, I just popped the pin and threw the grenade into the room, and waited for it to go off!!!![]()
drawson said:which was up from 465 when it was just balanced stock.
