P2229 Code. Barometric Pressure High
Gave up on the 6.7 diesel now back to gasoline
? on new code
Do you have any other codes in memory?
Looks like you may need a new IAT/MAP sensor, but it could be wiring or an ECM issue as well.
Are you good with a multimeter?
Well it showed three codes. CC Filter change, Generator Sense High, and Bar Press High. This call came about when my battery term was loose and I pulled it off while it was still running. I have cleared them but didnt run truck yet to see if codes come back. CC Filter was changed a few months ago.
