As some of you may know, Ive been rebuilding a 94 Cummins to swap into an 82 Chevy. Well I just got done rebuilding it and everything went smoothly until I went to start it. I got everything bled of air and also primed the oil galleries. Then I went to start it and it wouldnt go, just puffs of smoke and the sounds of it wanting to start. It sounded like it was out of time. I then took off the number 1 and 6 valve covers and made sure I had the cam in right by looking for valve overlap in 6 and then pinned the engine to TDC. I then took off the plug on the pump and found that the little tab that should line up with the pin in back of the plug was not lined up, not even close. So I then took off the gear on the pump. The gear came off way to easy ( didnt even need a puller). I torqued the nut to 144 ft lbs and I didnt forget the lock washer or anything so I dont know what the deal was there. So now I got the engine and pump pinned to where they are supposed to be. It seems that the problem was the gears either slipped on the shaft or when I tightened it the gear moved on the shaft. First of all, is there supposed to be a key on the shaft? There is a slot for one, but I dont remember having one on there when I disassembled the engine. If not, then why after tightening the gear to the proper torque spec would the gear come off so easy? Is there something Im doing wrong? By the way, Im getting a new lockwasher from Cummins tomorrow just in case. Im just worried that somewhere down the road the gear might slip on the shaft and Ill be stranded. Thanks in advance for any advice.
Tyler
Tyler
