We installed a simple regulator so we can adjust the air bags when we change loads... since the air bags require a minimum of 5 psi... we also installed a 5psi back check valve we got at a local hose company... . the 5 psi back check keeps at least that amount of air... and if there is ever a line failure it will hold this pressure in the bags...
We do nothing more that pay attention on how the back of the truck looks... load the truck and/or trailer and than add air to the bags to bring the truck back level... .
Very simple and easy to do... on one of the trucks that we tow a lot with, this regulator is on the back of the truck so its easy to reach as the load changes... on my 05 that I tow my 5er with its under the dash... On the 5500 we installed a trailer leveling valve so its automatic... each is different but suits the needs of how the truck is used...
