Pacbrake compressor won't shut off...
Tach and/or Cluster Repair Option
Wind Noise
First, thanks for all of the previous advice... I have sort of an emergency question... I just finished re-wiring the new air tank and compressor for my Pacbrake... question is:
When I turn the key on, the compressor kicks on to fill the tank with the Pacbrake switch in the off position... is this correct?
Or do I have the main wire to the solenoid relay and compressor relay reversed?
Thanks!
Are there 2 switches for the compressor/brake? If not then I would assume its normal, you need air to run the brake and the 1 switch is for the brake.
But, if it is wired backwords does it shut-off if you turn the switch off?
Mine has one switch and it only turns the brake on and off. The compressor runs independent of that switch (has a pressure switch that controls it) to ensure you have adequate air when the brake is turned on.
DZinger is right, that is how you wire it using the kit supplied. I opted for a second switch to run just the compressor. I also installed an LED light to let me know when the compressor is running. That way if the compressor runs for extended periods of time , I know I have a major leak in the system. and wont burn up my compressor
Thanks guys... I've got something haywire... pressure switch isn't shutting the compressor off, guess I'll tear into it after the weekend.
I just went through this same problem of the compressor not shutting off. Fortunately, I had a separate on/off switch just for the compressor, like DZinger does. The factory compressor has a pressure switch that should shut off the compressor when the tank reaches 130psi, and turns the compressor back on when pressure in the tank hits 110psi. That gave me a place to start troubleshooting the system.
In my case it turned out to be a combination of two problems: the brass fitting on one of the lines had come loose, allowing an air leak. And the pressure relief valve on the reservoir tank needed cleaning. Apparently a bit of gunk must have gotten in there, so it was releasing pressure from the tank before hitting the 130psi threshold.
Get yourself a spray bottle with some soapy water and start looking for leaks!
