PacBrake no work
Pro Weld Super Cooler????
Sealing hot pipe to HX40
Posted that on Sat. I had run through some water and lost my voltage meter but had no problems with anything else till today, my pacbrake wouldn't work. I have power to the solenoid and unhooked the vacume cylinder and was able to move the exhaust brake freely. The vacume cylinder is stuck in the closed position and won't move. Any Ideas? DW
If you are getting power then you can take apart the solenoid with a small allen wrench, spray a little wd-40 in it. and try again. if that doesn't work buy a new solenoid. i just went throught the same thing. I ended up calling Pac Brake and they told me to call Gateway diesel in Penn. they sent me a new on for $70. problem fixed works great.
Fixed
Called Pacbrake and they had me download a cleaning procedure from their website and that fixed it. DWest
