Need some information from you guys or gals that have installed your own PacBrake with the optional Switch-Pac that you mount on the shifter instead of the panel. My question is, how does the switch activate the exhaust brake butter fly. Thier is no wires leading to the air compressor from the switch. The switch wires, the black wire is a ground and the white wire goes to Pin# 39, when I checked for power the white wire had no power and I had the engine running plus I checked with a test light and made sure the pin was seated good. Thier is not a fuseable link for the switch. I put a 10 amp fuse in the fuse box in the engine compartment and still no power. This is a new unit that I just bought. I checked the pressure switch also and it was bad. Would the pressure switch have any thing to do with the Switch-Pac? Sent for a new pressure switch and received the wrong one yesterday. Have any of you have any problems with your electrical. Any and all answers greatly appreciated.
