I guess my first question would be what are your egt's now? My second question is what do you use your truck for?
The DZ will move much more air. On top. The PDR35 will have better bottom and mid (as will your stock 35/12). And if you want to use your stock 12cm housing on a DZ (which I highly recommend if you tow), you'll need to figure out a way to adapt your compressor-mounted wastegate actuator to the exhaust housing-mounted version that the DZ uses.
But first, figure out if you really need a larger turbo. The only thing you gain by going to big is lag.
EGT-wise, I probably had about a 100* drop between my DZ and my stock 35/12 with my Mach 2s and Comp on level 1 (EZ mode). With the Comp on 5x5 it was more like 200-300*. But that was at full throttle. Everywhere else, and especially towing, the stocker out cooled the DZ (even more so at altitude).
At your horsepower level the PDR35 will probably net you about the same egt reduction as the DZ with much better spooling.
