AH64ID
wheel was from an 06 IIRC so maybe a difference in the years?
Actually turbo speed has nothing to do with it. The ECM monitors for boost pressure and opens a solenoid that sends air to the WG that regulats boost in the ~28-32 psi range. It take the ambient pressure and manifold pressure to determine boost (one of the reasons a dirty air filter manifests with low boost pressure on a stock 04. 5-07).
Assuming you're correct, then what is the purpose of the speed sensor?
There is no speed sensor.
I'll assume you're right again. Then what is the device the green wire with the three terminal plug is connected to? I hope you're not going to tell me there's no green wire.
I know two people with '06 and '07 Dodges, I'll contact them and ask them about the green wire.
looks like a sensor the volvo's had.
